The image in the wav files do not work. Are there any specifications for attaching images to these files? Thanks
What do you mean
Do you see them in MP3tag? Then they do work. (At least that's the way it is on my PC).
Your player does not show them? Well ...
Perhaps your player is satisfied if you export the cover to the file folder.jpg.
