I'm puzzled: I've found the export function alright, but cannot find the corresponding import. What good does it do to be able to export tags, if you cannot use them on a different set of files. In this case I hava fully tagged set, and want to use these tags on a set of better quality (= same music) to avoid the rather complicated tagging (opera!). Any ideas?
Sheygetz
