Hello,
I come back to the _SEPARATOR function to configure the tags panel.
I thought this created a real separation on the panel.
It offers at most a SIMPLE LINE RETURN even if several _SEPARATORs are inserted in a row.
It has no effect if the cells in the row above are too wide.
In fact it should be called "_carriage return"
The ideal would be to insert a blank line or a line of characters of our choice like ************** REGARDLESS OF THE SIZE OF THE CELLS BEFORE AND AFTER THIS LINE.
This would be done as follows, for example:
Field: _SEPARATOR
All other options would be grayed out.
If this is too complicated to achieve, we could at least have the possibility of inserting several _SEPARATORs in a row.
Sincerely
