Anyone know how I can get the filter string to show files with the character ? in the field? Simply entering ? fails - it appears that ? is secretly reserved for some special meaning, presumably windcard. (V2.35a)
Also suggestion to developers: cover the filter string in Help.
There's no / filter by default, maybe once you entered this as a new tag field by mistake.
The entries in the filter are also derived from the fields you get when you make a new tag in the "Tags..." dialog.
You can edit the registry or in the latest version, there's a Shift+Del shortcut.
Registry:
HKEY_CURRENT_USER\Software\Moebius\Mp3tag\Settings
The string TagFields holds all the entries.
Shortcut:
Go to the "Tags..." dialog and click on the button. Now choose the field you want to remove and then press SHIFT+DEL.
Then choose any different field and enter a value and press the OK button (this is important).
Back in the "Tags..." dialog, hit Cancel and restart the program.
