in the column headings, between album artist and disknumber there is a BLANK field
i can tick this and it shows artist and title, just wonder why its blank thanks
Please show us a screenshot of the column definition.
You have created a column but not set the property "name" for that column. Or you have editted the column definition and deleted the orginal name.
So can I delete this
Thanks
I don't know.
You would have to check the column definition which includes settings for field and value besides the name.
It could be that it reveals something useful.
If I reject this if gives me a column with artist and title....can't see how to edit it delete it
The best description how to handle the column definitions can be found in the documentation:
yep that worked perfectly
thankyou
