Is there currently any way to do this?
You can use the variable %counter% to find out which position an item has in a sequence and use the variable as contents for e.g. %track%.
Sorry to be unclear. What I want to include is Auto-numbering Wizard operation. I am aware that %counter% can be used, but I doubt that can reproduce the ANW function.
Look, what I found in the forum:
Can I invoke Auto Numbering Wizard from 'Actions' ?
"It's possible but only for one album/directory because there's no way to reset the counter"
Thanks ![]()
Yep, I had already asked it and got the same answer
Tag - Filename [Track Number Code]
Thanks - wish posted: /t/10531/1
