Incorporate Disc number with Track number
Hi. I've searched if my query has previously been covered but I found no info. If I've made a mistake I apologise.
I'd like to automatically add Disc Number to the track number as you can do via the Windows version, e.g. Multi disc set of four: Track two (of 14 tracks) from CD1 would show as: 01-02/14. I use this for some devices that do not sort by Disc Number. Otherwise I'd get all the 1s, then all 2s etc... I hope I'm not too vague.
Thank you.
Hi and welcome!
If it's really about prepending the disc number to the existing track field, then you can use Convert → Tag - Tag for TRACK with $num(%discnumber%,2)-%track% as formatstring.
If you have something different in mind, please let me know :slight_smile:
Thanks for replying. Yes, this formatstring worked like a charm. Great!!! This makes it so much easier to sort. Again thank you.
