This is a strange one so I'm not sure if this is a PC setting or mp3tag setting.
When I have a folder of mp3 files on the desktop & create a playlist the list is generated in alphanumeric order.
If that folder is copied to a pen drive and mp3tag is asked to generate the playlist the order is not alphanumeric.
I'm not sure what order the files are in, as it is not by date or size as far as I can tell.
This is probably best illustrated by an example:
Mike Oldfield - Ommadawn; located on pendrive gives the following playlist:
Mike Oldfield - Ommadawn (2010) - 03 - In Dulci Jubilo.mp3
Mike Oldfield - Ommadawn (2010) - 04 - First Excursion.mp3
Mike Oldfield - Ommadawn (2010) - 06 - Portsmouth.mp3
Mike Oldfield - Ommadawn (2010) - 01 - Ommadawn Part One (2010 Stereo Mix By Mike Oldfield).mp3
Mike Oldfield - Ommadawn (2010) - 02 - Ommadawn Part Two - On Horseback (2010 Stereo Mix By Mike Oldfield).mp3
Mike Oldfield - Ommadawn (2010) - 05 - Argiers.mp3 -
Mike Oldfield - Ommadawn; (same folder) located on desktop:
For comparison here is the Dir output from a cmd prompt:
Directory of C:\Users\xxxxx\Desktop\Ommadawn 2010-5326762 Album
29/04/2015 15:10 .
29/04/2015 15:10 ..
16/06/2012 12:57 46,135,052 Mike Oldfield - Ommadawn (2010) - 01 - Ommadawn Part One (2010 Stereo Mix By Mike Oldfield).mp3
16/06/2012 12:56 42,086,117 Mike Oldfield - Ommadawn (2010) - 02 - Ommadawn Part Two - On Horseback (2010 Stereo Mix By Mike Oldfield).mp3
16/06/2012 12:50 7,183,254 Mike Oldfield - Ommadawn (2010) - 03 - In Dulci Jubilo.mp3
16/06/2012 12:57 14,477,687 Mike Oldfield - Ommadawn (2010) - 04 - First Excursion.mp3
10/06/2012 22:20 9,871,753 Mike Oldfield - Ommadawn (2010) - 05 - Argiers.mp3
10/06/2012 22:47 5,131,060 Mike Oldfield - Ommadawn (2010) - 06 - Portsmouth.mp3
29/04/2015 15:09 793 _Ommadawn 2010-5326762 Album.m3u
Any idea what is going on here?
OS is Win 8.1; The pen drive it Bitlocker encrypted (as is the OS partition) & is set to 'trust' the pen drive so automatically unlocks the drive when connected.
The fact that mp3tag writes the playlist means that this shouldn't be an issue.
Anyone come across this issue before?
Many thanks
Stellar
