Is there a way of increasing the number of memorized LRU directories?
I have more directories than the LRU list allows. And it would make it a lot easier for me to switch between them.
Thank you.
Thank you.
did you know that you can drag & drop folders from the explorer in MP3tag.
Might make opening even easier than the dropdown list as you can drag more than one folder in one go - something the dropdown list does not allow.
