The tag panel is now (since the addition of cover art, I guess) too big for the space provided for it on install, causing a vertical scroll bar, which itself partly covers the field drop-down so causes a horizontal scroll bar. I suggest the window be made slightly taller to accomodate.
Also the initial window position is bottom right corner of desktop. Centre would be neater!
