I'm trying to insert the ":" character in comment field in some specific positions (after the 10th and 15th letter from the beginning and the end of the text). After searching (/t/967/5 the only thing that come is how to insert at the end (appending).
Do you have any idea on how to do that??
Thanks
PD: It would be nice to learn how to insert a string of characters also at specific positions, or after some characters.
Get yourself aquainted with the scripting functions $LEFT, $MID, $RIGHT, $LEN
Use these functions in an action of the type "Format tag field".
To insert a : at position 11 in TITLE use this construction:
$left(%title%,10):%mid(%title%,10,$len(%title%))
For "inserting after some characters" you could use the action "Replace with regular expression" - but for this it is necessary that that "character" is part of a unique pattern.
Beside the shown fundamental string manipulations you can choose the fitting string function for your problem out of a set of string functions.
The functions $replace and $regexp are often used too.
See Mp3tag manual "Scripting Functions".
