Install issue - when installing it seems to get hung up
Seems to get hung up listing thousands of files - ran for 30 min, had to go to task manager to kill process. After kill I went and loaded it and program comes up ok but it shows dialog box, MP3 3.32 - Help system not available - please reinstall 3.32" but when I close this and 3.37 loads ok. Mp3 is loaded on D drive under Programs.
Looks to me like you installed different versions on top of each other.
I would
  • save the configuration first in a good place apart from the MP3tag folders,
  • then un-install the current version
  • and if there are still traces of a previous version remove these as well.
  • and then install from scratch,
  • import the configuration from the saved location.
Are there thousands of files in the directory you're installing to?
Yes re thousands of files. Does it have to read entire file directory at install?? Will try reinstall
Yes, it reads the directory contents to calculate the used disc space for the installation. Please use a folder that does not contain files unrelated to your Mp3tag installation.
Ok, did uninstall and reinstall. Now loads ok. But new problem: When it lists the files, on some files there are big red circles w an X next to Title, and even though the file recording length shows in Explorer in Mp3 some files do not show length. In this case there are 3 files n the folder, first one shows length, second and third are blank. What's up? Thanks
If you have a separate problem, please use a separate thread for the new topic.
