Hello Florian,
Would you consider adding a ditto command in MP3tag to reproduce the previous cell on the working cell (as CTRL , in Excel or Access) like in many databases.
Thank you in advance.
Sincerely, Bruno Le Glay.
I think that function is already there and even a little more sophisticated as you can select any quantity of files and, using the tag panel, you can apply any entry that is already there or enter something completely new in one go.
BTW: by selecting a the next track it would be rather difficult to find out, which of the last actions should be applied...
