In my export I have
$loop(%_file_create_datetime_raw%)Which works fine, but it sorts in ascending order (oldest first), is it possible to reverse the sort? i.e. from newest to oldest file?
Thanks
Steve
In my export I have
Thanks
Steve
In this case you can use
$loop($sub(%_file_create_datetime_raw%,10000000000))
Excellent!! Thanks
