Iriver H320
Help
new to this forum and the H320, is there a easy way to edit the filename lenght to 52 characters as this is the limit of the player
Create a new action "Format values". Select "_FILENAME" as field and use "$left(%_filename%, 52)" as format string. If the extension is included in the 52 character limitation, tell it to cut at 48 characters.
Many Thanks Sebastion
just tried it but get this response 2 couldnot be renamed, sussed it a typo, many thanks
