Hello,
I wanted to ask, I was able to manually add a txt section from tag panel for WWW.
Q:Is there a way to link this metadata so it shows up when I export to a NFO file?
Thank you!
NFO
Hello,
Thank you!
NFO
If you know in which field you have stored the www information, then use this field in the export script.
The standard field for an url would be WWW or in export: %www%
Thank you. This has solved my problem! It worked as you stated.
This thread may now be closed.
NFO
