This I didnot do myself either, please keep in mind that I learned about MP3Tag only last week.
I even think that when I have the proper coding, this may be all I ever will need.
This is too much information I do not need..
With the concerning export script I get too big a list which I cannot insert in front cover
of the cdcase.
I have been studying what could be deleted but have no idea.
I thank you for the time you devoted to my question.
Hehe, nothing learned in the meantime?
Ok, back to your first posting.
You want to align the playing times exactly below each other and you have asked if this possible and how you can achieve this.
The answer, part one, is "Yes, you can"!
The answer, part two, is as following:
If you want to align tag field content resp. text columns on simple text output, then you have to do some string manipulation in order to set each column to a fixed width.
In general numerical columns are aligned to the right edge and textual columns are aligned to the left edge.
Left aligning resp. truncating at the right edge can be coded like following, e. g.
$left(%ARTIST%$repeat('',40),40)
Right aligning resp. truncating at the left edge can be coded like following, e. g.
$right($repeat('',7)%LENGTH%,7)
For aligning the tracknumber you may simply code:
$num(%TRACK%,2)
As I do not know exactly to which width your columns have to be truncated to fit on the cover sheet you have to do the math for yourself.
Keep in mind that this method will give readable aligned result only when using a fix pitched printer font like "Fixedsys" or "Courier New" or "Lucida Console" or some other "Mono"-spaced font type.
I gave it a try, but I am at a loss where I have to insert the adaptions you mentioned
and therefore result was not good.
Occassionaly I want to make such a list and therefore I do not want to do a lot of trial and error
in order to reach the required result.
This is not neccessary either.
A friend gave me her software of MP3Collector, since she had no use for it anymore.
This is a very userfriendly application since within half an hour I got the result I want
(see the attachment)
Well, you now offer a result which is in fact a html page including a table - and this is equivalent to my proposal from posting #2 of this thread (because I know the problems with formatting pure text as you wanted to do ...). Now you points this out what I've said: it might be easier to create a well formed list by a html page and print the html page via browser using any proportional font you like.
Mp3tag delivers some standard beginners mte html scripts. Additionally look into the forum export archive, there are a bunch of similar html export scripts, learn to use them and try to adapt them to your needs if necessary.
This may look like that what you've want, but it was not the way you've started and gone so far...
*** It always helps to know what exactly is desired. ***
After all desperation you should take some time to learn more about the magics within M3tag.
This is not the ready made button to click (though, I miss this button too ...), but it is the power of the open workbench (which you do not find in other feature limited applications).
In my opinion I did exactly asked what I wanted, but never specified which output format (txt, html).
But this thread has become so complicated that there was plenty of room for mutual misunderstandings.
Anyway I did a lot of browsing based on the links you gave me, but I didnot found what I wanted.
Since I now have this I do not see any reason why I should not close the subject, but not before I thank you for your attention you devoted to the subject.
Though I prefer that it had come in the form of ready solution.
