I'll explain better with two examples:
1st
One thing that happens a lot is that my files are called 1 - Title, 2 - Title etc, so every time, for the first 9 tracks, I have to do:
- Tag - Tag --> FIELD: TRACK & FORMAT STRING: 0%track%
- Tag - Filename --> %track% - %title%
I'd like to know if it's possible to store this sequence of operations somewhere and then call it when I need it
2nd
I make a lot of playlists and for each of them the process is the same: I set the title equal to the filename, I then remove every tag and assign Artist, Album, Genre and Cover tag by hand. Since the chosen tags are the same every time, I was wondering if there was a way to automatically tag files based on a "pattern" that you save somewhere.
Hope the examples' explanation will make you understand what I want to do, thanks in advance!
