Imagine getting an album full of fields you don't want.
Do we have a way to delete all existing (found) fields at the start of a Web Source Script to have full control over what the following script writes into to the files?
(I know that I could use an Action "Remove Fields expect".
But I'm looking for a "script-only" solution.)
Any ideas on how to do this if you don't know which fields exist?
then you keep a user-defined field called COVER (which is probably not there anyway) but most likely not the embedded picture as the field name for that is PICTURE as written in the documentation and quoted by @LyricsLover.
Well, that's strange, because i don't remember creating any user-defined field for the cover image, i always believed that I used the default one, but nm, it works fine for me lol.
No, it's always a merge operation in the Windows version of Mp3tag. The macOS version is slightly different as it provides means to overwrite existing or merge with existing tag fields.
However, it's not possible to influence this from a Tag Source. This is intended and by design.
