Is it possible to edit multiple titles at once
I have a bunch of newly downloaded mp3 files that have the file name incorrectly done.
Here is a example of the song “Random: Random Random Random Random | Random Random Random Random [ofbnvjfnvfovn]”
Here is how I want to edit the file name “Random: Random Random Random Random” I want to keep everything before the | and delete everything after it and go 1 space before the | since there is a space after the last letter.
Like this:
The Red Car |
The Red Car|
There is a space like for the first example and I want to try and remove the space and the | and everything after it. Is this possible with mp3tag?
And these are the File Names not the titles. I will edit the “Titles, Albums, And Artists” once the file names are done there are only like (3) album titles and 1 “Artist” so that stuff will be pretty simple. But the whole renaming of the (62) files one at a time will take me a few minutes. So I’m trying to find a simpler way. Thank You in advance.
The easiest way would be to fill the tag fields for
and then rename the files with the metadata and the function Convert>Tag-Filename.
