I use mp3tag to tag my files using Musicbrainz album information. I noticed that when tagging it seems to use curly apostrophes as the default. However, I'm trying to figure out if it's possible to make straight apostrophes the default instead.
If that's not possible, is there an action I can use to change curly apostrophes into straight apostrophes for song titles?
For reference, if I individually edit the titles and type in an apostrophe with my keyboard, it shows as a straight apostrophe.
means that you use a community driven source that may have its own standards.
And perhaps there are other users who like to get the data as it comes from the source.
So, no, there is no way to set that kind of standard. But you are free to do any kind of post-processing.
