For my script for mixesdb.com I would like to display the file details from mixesdb.com in the _LENGTH field of the "adjust tag information" dialog.
I found out by testing that _LENGTH is only displayed when there are more than one track. And that has the consequence that Mp3Tag writes tracknumbers into TRACK. But I don't want to overwrite the existing tracknumber, because dj sets are most of the time single mp3 files and TRACK is (miss)used by many podcasts to count their episodes.
So my question:
Is there a way to set TRACK back after using outputto "TRACKS"?
set "track" does not work
set "tracks" works but is useless as it disables the view of _LENGTH
Or is there any other way to display _LENGTH or any other dummy field which is not written into the tags? I tried outputto "DUMMY", but that does not work in the way I would have favoured.
This is the script part I used to get the file details into _LENGTH:
findline "> File Details <"
joinuntil "</table>"
outputto "tracks"
sayoutput "title"
say "|"
outputto "_length"
killtag "*"
RegexpReplace "File Details.*dur.*MB.*kbps (.*?) (.*?) (.*?) " "$1min - $2MB - $3kbps"
sayrest
say "|"
outputto "tracks"
sayoutput "title"
say "|"
outputto "_length"
say "1"
say "|"
