I've looked on this forum for a FAQ and if it's here I missed it. My question concerns email notification of development builds. Is there such a list? I'm hoping "track this topic" on your sticky is the way to do it.
I haven't posted anything for quite a while because Mp3tag is much more troublefree since when I first started using it, mostly because of your great work Florian, but partially because I'm more accustomed to how it works.
I don't think that tracking the topic will notify you, as Florian is only editing the thread (AFAIK) - the notification function works only if someone replys.
Oops, if d4n0 says that it works, that should do the trick then.
If you'll notice, Florian doesn't edit his followup post. It's a new one each time. He has delete rights being the moderator. This is not the only forum I'm on where an edit doesn't generate an email or unread mark. It's a poor choice for forum design because sometimes moderators are not even made aware of edits.
I'm editing the main topic with each new development build, but I delete the release notice each time and add a new one to make the forum send the notifications.
This should work, since I notice a increase of the visitor count each time I release a new development build
