I just want to know how/if I can use the Codepage Conversion action to correct unicode ID3 tags that are in Hebrew? I have used this option many times to correct tags in Chinese, but I do not see Hebrew listed to correct these tags. Please help.
Depending on your OS (like Win XP) you might first have to install hebrew language support.
Tried that. I have the language package installed, but I simply don't see "Hebrew" listed in the drop-down of languages when I'm under the Convert Codepage option under Actions.
