Hi, I am a new contributor and very basic user. This seems to be the question I am asking. My duplicate (backup) file meets the criteria you state and I wish to copy/paste tags to it. Please could you point me to the instructions for this or give a brief explanation? I would be very grateful. Thanks in advance.
On edit: I have exported to both html and csv files but using the convert function just drops the text info into one field. I presume I need to format the string chain but that isn’t intuitive to me.
Export to CSV (or any other format that exports one file per line) is the way to go. Please check this topic from the documentation, and -- if any questions remain -- don't hesitate to ask:
Alternatively, you can just load the original files and the duplicates and copy the metadata from the original via Ctrl+C and paste to the duplicates via Ctrl+V.
Thank you. My csv file has column info (separated by semicolons) and tag info. When I use convert text file to tag it pastes only the column info (separated by semicolons, including some columns I haven’t selected) into the sixth column (album artist). Adjusting the format string doesn’t seem to affect this.
I don’t have a background in computer language I’m afraid. I use the cut and paste method you suggest at present but it is too time consuming for the backup process I wish to complete. Im also interested in taking advantage of the functionality of this powerful programme.
The cut&paste method means:
Select all the source files
use Edit>Copy
(which copies the whole tags)
Select all the target files
use Edit>Paste
(which pastes the whole tags)
So it is neither tag field by tag field nor file by file.
The assumption is that the
