I have a single file with my .mp3 files in. I always use the command to rename as %artist% - %title% to minimise duplicates (music library used for DJing, so don't care about having pristine album collections with all tracks, including duplicates and so on).
Sometimes I run the Tag - Filename action from the menu bar using my chosen filename convention. However, I will sometimes get errors saying a file cannot be renamed, which is where the file already exists and it cannot rename due to it being being a duplicate.
Is there any way to have mp3tag either delete these failed renaming files or to moving the failed files to a separate folder or something?
The error log prompt box is what I use at the moment to identify the failed duplicates one-by-one, but can be time consuming if there's a few, which inveitably can happen when its a library of tens of thouands of .mp3 files.
