Is there a way to customize track & disc numbers? I want the default for both track numbers and disc numbers to be 2 digits. ex 01,02 etc.... Is there a way for me to tweak something in an ini file or somewhere else to make this happen? I know I can add a leading 0 manually, I want to change the default so I don't have to do it manually. Let me know and thank you.
You can use an action Format value to change this for multiple files at once but there is no preferences option to make this the default.
