Does anyone know if there is an easy way to remove the Lyrics from MP3 files without deleting the other tags as well?
Load the files into MP3tag
Select the files
Press Atl-T to open the extended tags dialogue
Select the field for Lyrics (e.g. UNSYNCEDLYRICS)
Click on the Delete button next to the field list
Click OK to save the modification.
Done.
I hope that was easy.
If you are speaking about the tagtype Lyrics3v2, then find something there ...
https://www.google.de/search?q=site%3Aforum...ag.de+Lyrics3v2
DD.20160115.1153.CET
