Hi, I'm using Mp3tag since couple of months. It's a great software. Congratulation !
I added a new column in view named Isrc. Now I believe that this info is not available from Discogs but I know that MusicBrainz has it.
If I retreive tags info from MusicBrainz nothing is coming in as ISRC but I know that they have it
Do I have to add %isrc% or something else somewhere ?
Thank you for help !
MrMix
If you look inside the used WebSourceScript* (I assume you are using "MusicBrainz.src"), you will NOT find any hint that the ISRC will be parsed.
The fact that MusicBrainz collect this number does not guarantee the availability in a WebScript.
°* WebSourcecripts are pure text files. You can open it with any text editor, like Notepad.
Thank you for the reply.
Yes I checked and I did not see it.
Would it be possible to manually insert the search of this field ?
I have no clue how to do it !
Thanks
MrMix
You could ask in this thread:
Just be aware that remasters/editions of an album have different ISRCs, so you need to know exactly which edition you have and which one you're importing. I'd say there's a high risk of getting the wrong ISRC.
