Issues using bandcamp for tagsource
The bandcamp file tagging does not work for me anymore. Im using both the latest version of Mp3 tag (but i already had this issue before update, updated it to see if it got fixed) and the latest version of the bandcamp tag souce. it worked perfectly fine for me before and it suddenly stopped working. Not sure if its user error or if the issue lays somewhere else.
image below is when searching album title
and this appears when searching with an url.
Can you check the Bandcamp URL tag source I've uploaded here and let me know if it works for you?
hey thanks to the response, ive found that post before i posted the msg and sadly it gave the results i posted above. i made sure to remove the 0.4.3 version aswell.
OK, I think I found the issue. Can you retry using this version?
bandcamp-0.4.4.zip (2.6 KB)
ah perfect, that fixed the issue with the URL search!
