I would like to report a potential bug regarding UNSYNCEDLYRICS in m4a files in v3.32.
I am currently using v3.32 on my desktop and v3.30 on my laptop. I noticed that lyrics written to m4a files using v3.32 do not appear on my smartphone (Musicolet app), whereas they work perfectly when using v3.30.
Here is the summary of my situation:
mp3 + v3.32 (UNSYNCEDLYRICS) → Working
m4a + v3.30 (UNSYNCEDLYRICS) → Working
m4a + v3.32 (UNSYNCEDLYRICS) → NOT Working (Lyrics not detected)
As we do not have you test app and your smartphone:
could you check the extended tags dialogue for the files where it works and those where it does not work?
The first screenshot is the dialogue of the working file, and the second one is from the file that does not work. The contents of UNSYNCEDLYRICS are same.
I’ve just checked the latest version v3.33.1, and it seems the bug has been fixed. Everything is working correctly now. I appreciate your help with this.
