iTunes 7 Websource
#1
Can someone make a websource for http://www.augistyle.net/itunes/album_art_form.php ? I've tried many times, but have been unsucessful.
Thanks!
Get Cover Art from iTunes
#2
:santa:
#3
Thank you so much! :slight_smile:
#4
This doesn't seem to work anymore. Can you fix this?
Thanks.
#5
It still works (no error in the src) but many covers are now encrypted by apple!
#6
Well thanks dano. I though it was the script itself. Hopefully someone can figure out a workaround for that encryption.
#7
It's pretty weak encryption, from what I've seen on various sites it's simply a wrapper around the jpeg with a header record.
#8
Do you think that you can change the script or make a new one that works around the encryption?
#9
I've been watching for a script or a utility that strips the header out, all I've seen so far is a UNIX version.
The source script is available on this site, I haven't played around enough to see if it will work in the web source framework.
I'm guessing a few of the regulars could take a look and determine if it's feasible fairly quickly.
#10
No, this isn't ITC, this is a real encryption.
http://marv.kordix.com/archives/000927.html
#11
oops, my bad. Sorry - should have paid more attention, the file is unencrypted into the itc format after iTunes downloads the art.
