I know this is random but do you have an updated version of this script? I'm a noob in python and I'm getting a bunch of errors. Not sure if it's just a new version of python or if I have errors in my code.
My code is exactly the same as yours just with a different directory.
Here's the errors I'm getting
Python 3.7.4 (tags/v3.7.4:e09359112e, Jul 8 2019, 19:29:22) [MSC v.1916 32 bit (Intel)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import requests
>>> import json
>>> import re
>>> import os
>>> import mutagen
>>> from mutagen.mp4 import MP4
>>> source_dir = r"C:\Users\Riley\Desktop"
>>> for i, name in enumerate(os.listdir(source_dir), start=0): # iterate over all files/directories in source_dir
... if name[-4:].lower() != ".m4a": # ignore non-mp3 files
File "<stdin>", line 2
IndentationError: expected an indented block
>>> continue
File "<stdin>", line 1
SyntaxError: 'continue' not properly in loop
>>> path = os.path.join(source_dir, name) # build the whole file path
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
NameError: name 'name' is not defined
>>> # you can also check with os.path.isfile(path) to make sure it's a file you're processing
... # etc. (your mutagen update logic)
... audio = MP4(path)
File "<stdin>", line 3, in <module>
NameError: name 'path' is not defined
>>> if i == 0:
... lookupid = audio["cnID"]
>>> lookupid = lookupid[0]
NameError: name 'lookupid' is not defined
>>> break
SyntaxError: 'break' outside loop
>>> # lookupid = int(input("AppleStoreCatalogID: "))
>>> print(lookupid)
>>> a = ('https://itunes.apple.com/lookup?country=US&entity=song&limit=200&id=%i' % lookupid)
>>> b = requests.get(a).json()
NameError: name 'a' is not defined
>>> geID = b['results'][0]['primaryGenreName']
NameError: name 'b' is not defined
>>> geID = re.sub("Blues", '2', geID)
NameError: name 'geID' is not defined
>>> geID = re.sub("Comedy", '3', geID)
>>> geID = re.sub("Children's Music", '4', geID)
>>> geID = re.sub("Classical", '5', geID)
>>> geID = re.sub("Country", '6', geID)
>>> geID = re.sub("Electronic", '7', geID)
>>> geID = re.sub("Holiday", '8', geID)
>>> geID = re.sub("Classical|Opera", '9', geID)
>>> geID = re.sub("Singer/Songwriter", '10', geID)
>>> geID = re.sub("Jazz", '11', geID)
>>> geID = re.sub("Latino", '12', geID)
>>> geID = re.sub("New Age", '13', geID)
>>> geID = re.sub("Pop", '14', geID)
>>> geID = re.sub("R&B/Soul", '15', geID)
>>> geID = re.sub("Soundtrack", '16', geID)
>>> geID = re.sub("Dance", '17', geID)
>>> geID = re.sub("Hip-Hop/Rap", '18', geID)
>>> geID = re.sub("World", '19', geID)
>>> geID = re.sub("Alternative", '20', geID)
>>> geID = re.sub("Rock", '21', geID)
>>> geID = re.sub("Christian & Gospel", '22', geID)
>>> geID = re.sub("Vocal", '23', geID)
>>> geID = re.sub("Reggae", '24', geID)
>>> geID = re.sub("Easy Listening", '25', geID)
>>> geID = re.sub("J-Pop", '27', geID)
>>> geID = re.sub("Enka", '28', geID)
>>> geID = re.sub("Anime", '29', geID)
>>> geID = re.sub("Kayokyoku", '30', geID)
>>> geID = int(geID)
>>> geID = [geID]
>>> print(geID)
>>> atID = b['results'][0]['artistId']
>>> atID = [atID]
NameError: name 'atID' is not defined
>>> print(atID)
>>> sfID = b['results'][0]['country']
>>> sfID = re.sub("ENG", '143441', sfID)
NameError: name 'sfID' is not defined
>>> sfID = re.sub("DEU", '143443', sfID)
>>> sfID = re.sub("CAN", '143455', sfID)
>>> sfID = int(sfID)
>>> sfID = [sfID]
>>> print(sfID)
>>> plID = b['results'][0]['collectionId']
>>> plID = [plID]
NameError: name 'plID' is not defined
>>> print(plID)
>>> for name in os.listdir(source_dir): # iterate over all files/directories in source_dir
>>> continue
>>> audio["geID"] = geID
>>> audio["atID"] = atID
>>> audio["sfID"] = sfID
>>> audio["plID"] = plID
>>> audio["pgap"] = False
NameError: name 'audio' is not defined
>>> audio["cpil"] = False
>>> audio.pprint()
>>> audio.save()
