I have located the MP3TAG tag field mapping for all iTunes fields . . . except the Description field. The Description field in iTunes is used for "TV Show" and "Movie" display in Apple TV.
MP3TAG writes to the "Comment" field. After importing the file to iTunes, I manually copy the Comment field to the Description field after entering "Get Info." This is time consuming.
If I could populate "Description" based on "Comment", it would save considerable time.
What is the iTunes field for Description that maps back to MP3TAG (and vice versa)?
NOTE: I've tried every field in MP3TAG that has the word or partial word "Description" in it. If I need to create a new field, what's the name? Details please.
You could try the other way round: fill a description field in iTunes and then load the file into MP3tag and see (in the extended tags dialogue) where you find the data.
Thanks so much!!! That worked! I updated the iTunes "Description" tag field. Then loaded back to MP3TAG and used EXTENDED TAGS DIALOGUE to find the metadata field name. It was "SUBTITLE!" I used MP3TAG to put the content of "Comment" into "Subtitle" and reimported into iTuens. Voila! Saves tons of time!
it has changed with the last release! I've added PODCASTKEYWORDS and did some minor changes. Generally spoken, the mapping should reflect the current status. In case you notice any oddities, please let us know.
