Can I update the iTunes TV/video tags? if yes what are their names? I can't find them in the dropdown list.
Thanks
JL
Thanks
JL
Yes, this is possible.
The fields are name ITUNESMEDIATYPE, TVEPISODEID, TVNETWORK, TVSEASON and TVEPISODE where possible values of ITUNESMEDIATYPE are
Great! Thanks... What about the show description?
It's ITUNESPODCASTDESC
I got the Episode ID and the show description to work but TVEPISODE; TVNETWORK; TVSEASON don't work.
Am I missing something? I added a customized column for each new fields and I
populated values in Itunes "Season Number"; "Episode ID"; "Show" tags in ITunes but they show up in Mp3Tag.
Thanks
JL
It seems TVEPISODE & TVSEASON is not read when tagged by itunes.
Can't test TVNETWORK because I don't know how to write it with iTunes.
Florian must check this ..
Also check the tags with "View > Exetnded Tags" Jean-Louis it's a good overview.
Fixed with Mp3tag v2.42c Development Build.
