So iTunes has created some issues (go figure). Apparently it has all the years that i have been fixing, but it wrote Track numbers to the Year fields on about 12,000 songs.
So my question is, is there some kind of tag field that iTunes gets the year from? I would love to be able to automatically fix the year somehow for an external DJ program.
Any suggestions welcome, but I fear it is in the iTunes Database only. Thanks!
You can check the extended tags if you find the year somewhere.
To get the year, you could create automatic playlists that get the track by the year in iTunes and drag&drop the result into MP3tag. In MP3tag you enter the year and save the modification. This should save the year in the tag.
