I'd like to know if there is a way to format ITUNESPURCHASEDATE from %_file_create_datetime%, then convert the format to the iTunes/Music.app format of YYYY-MM-DDTHH:MM:SSZ. I have the first part set using Format Tag Field.
Field: ITUNESPURCHASEDATE
Format: %_file_create_datetime%.
My system date format is DD/MM/YYYY HH:MM
