JSON: Parse (sub)structure
I start this new thread since the one I had sent the comment is marked as "Bug solved":Parse JSON (sub)structure.
There is no way to know json_select_object found the json object or not. Script is useless in big part of the cases.
Try attached script with different artists (Peter Gabriel, Dire Straits, etc). Pay attention to country name column which is set to artist name in many cases.
Let's hope the competent one would go through this thread. :sunglasses:
MusicBrainz__json__Artist.src (2.43 KB)
This is now changed in that way, that the name of the selected object appears at the current position if successful.
You can check it via
json_select_object "something"
if "something"
   json_unselect_object
endif
