I don't mind. But as I said, it's rudimentary, not tested and far from complete. I haven't touched it since september last year and I'd do quite a few things differently now.
import os
import subprocess
import math
import sys
import re
def get_bitrates(directory, extension):
files = [f for f in os.listdir(directory) if f.endswith(extension)]
bitrates = []
for file in files:
file_path = os.path.join(directory, file)
if extension == 'mp3':
result = subprocess.run(['exiftool', '-AudioBitrate', '-b', '-m', file_path], stdout=subprocess.PIPE, text=True, check=True)
elif extension == 'm4a':
result = subprocess.run(['exiftool', '-AvgBitrate', '-b', '-m', file_path], stdout=subprocess.PIPE, text=True, check=True)
bitrate = float(result.stdout) / 1000
bitrates.append(bitrate)
return bitrates
def check_for_flac_files(directory):
# Initialize a flag to indicate if .flac files were found
flac_found = False
# List all files in the directory
for filename in os.listdir(directory):
if filename.endswith(".flac"):
flac_found = True
return flac_found
def main(directory):
mp3_bitrates = get_bitrates(directory, 'mp3')
m4a_bitrates = get_bitrates(directory, 'm4a')
flac_exists = check_for_flac_files(directory)
# Regular expression pattern
pattern = r'^(.*?)(?: \[MP3 \d{2,3}\]| \[M4A \d{2,3}\]| \[MP3 \d{2,3}-\d{2,3}\]| \[M4A \d{2,3}-\d{2,3}\]| \[FLAC\+MP3 \d{2,3}\]| \[FLAC\+M4A \d{2,3}\])'
# Match the pattern against the directory
match = re.match(pattern, directory)
# Initialize new_directory with the original directory
new_directory = directory
# If there's a match, update new_directory with the captured text
if match:
captured_text = match.group(1)
new_directory = captured_text
if not mp3_bitrates and not m4a_bitrates and not flac_exists:
print("Directory does not contain .mp3 .m4a or .flac files.")
sys.exit(1)
if not mp3_bitrates and not m4a_bitrates and flac_exists:
print("Directory only contains .flac files.")
sys.exit(1)
if mp3_bitrates and m4a_bitrates:
print("Mp3 and m4a mix.")
sys.exit(1)
if mp3_bitrates and not m4a_bitrates and not flac_exists:
avg_bitrate = round(sum(mp3_bitrates) / len(mp3_bitrates))
min_bitrate = round(min(mp3_bitrates))
max_bitrate = round(max(mp3_bitrates))
if min_bitrate == avg_bitrate or max_bitrate == avg_bitrate:
new_name = f"{os.path.basename(new_directory)} [MP3 {avg_bitrate}]"
else:
new_name = f"{os.path.basename(new_directory)} [MP3 {min_bitrate}-{max_bitrate}]"
if not mp3_bitrates and m4a_bitrates and not flac_exists:
avg_bitrate = round(sum(m4a_bitrates) / len(m4a_bitrates))
min_bitrate = round(min(m4a_bitrates))
max_bitrate = round(max(m4a_bitrates))
new_name = f"{os.path.basename(new_directory)} [M4A {avg_bitrate}]"
else:
new_name = f"{os.path.basename(new_directory)} [M4A {min_bitrate}-{max_bitrate}]"
if mp3_bitrates and not m4a_bitrates and flac_exists:
mp3_avg_bitrate = round(sum(mp3_bitrates) / len(mp3_bitrates))
new_name = f"{os.path.basename(new_directory)} [FLAC+MP3 {mp3_avg_bitrate}]"
if not mp3_bitrates and m4a_bitrates and flac_exists:
m4a_avg_bitrate = round(sum(m4a_bitrates) / len(m4a_bitrates))
new_name = f"{os.path.basename(new_directory)} [FLAC+M4A {m4a_avg_bitrate}]"
os.rename(directory, os.path.join(os.path.dirname(directory), new_name))
subprocess.run(['mp3tag', '/add', f"/fn:{os.path.join(os.path.dirname(directory), new_name)}"])
if __name__ == "__main__":
if len(sys.argv) != 2:
print("Usage: python script.py <directory>")
sys.exit(1)
directory = sys.argv[1]
if not os.path.isdir(directory):
print("Invalid directory path.")
sys.exit(1)
main(directory)
These days I'd probably make it recursive as well instead of only relying on it being called with the folderpath.
I'd also use mediainfo instead of exiftool to extract the relevant audio information.
Also the flac bit depth and sampling rate aren't in it because back then I used an mp3tag action group to calculate these. As I said, it's highly incomplete.
I might take a stab at it when I'm done with my current project.
But feel free to let me know if it helps or if you manage to improve it.
