How to replicate his bug:
1] Load at least 2 files, one of them other than MP3
2] Play that non-MP3 file in your player
3] Select both of files
4] Choose for them Move... from the right click menu
5] When prompted by operating system about that one file being in use [by the player] choose Skip or Cancel
6] When prompted by Mp3tag about re-reading of the directory choose No
What happens? Mp3tag looses from sight both of the files, leaving on the list of files empty "files"; ghosts, shells, whatever you wanna call it. The have tag fields wiped out of data and fle themselves cannot be accessed by Mp3tag anymore
Prevention: do not move files like FLAC that are being played. But the user might simply make a mistake
Workaround: reread the directory. But the user might had loaded up multiple directories or some kind of a large collection, making the re-read option useless [i.e. not precise enough on the account of not rereading others folders] or too time consuming [in case of a tens of thousands of files on the list infected now with "ghost" files]
Solution: simply keep track of the moved files
