Keyboard shortcuts for convert previews are not working as documented
I'm not sure if this should be considered a bug, but the overview of available Keyboard Shortcuts lists previews for three Convert functions that don't work as expected and documented. The following key combinations
Alt+Shift+1 Tag - Filename (Preview)
Alt+Shift+2 Filename - Tag (Preview)
Alt+Shift+3 Filename - Filename (Preview)
should certainly provide the preview in my notepad++ editor immediately. Instead I get the same dialogbox as if I hadn't used the shortcut with the shift key. The combination with shift obviously has the same effect as the one without the shift key and that probably is not intended.
Furtheremore the dialogbox appearing has a preview button without support of a keyboard shortcut. I already had suggested one in Keyboard Shortcut für Preview (in german).
Thank you for pointing! I had a look at the source code and also picked a random ancient version (v2.88 in this case), and I think the shortcuts never worked (or only did for a very brief time).
I've updated the documentation for now, and will add a keyboard shortcut for the preview button with the next release.
I've added a keyboard shortcut for the preview button with Mp3tag v3.34-beta.3.
