What's the keystroke to enter edit mode on the tracklist?
I've been using F2 (edit filename) and then TAB/SHIFT+TAB to the field I want, but this doesn't work when there's no %filename_ext% column on display.
Thanks.
Thanks.
It's also [F2] with the current Development Build
Confirmed fixed in V2.39n.
But note that Help needs updating.
Thanks.
