Kind of Batch Tagging
#1
project stopped
Hotkey / auto select all tracks in next folder
Script for ripping genre, year & record label from beatport.com
Via Tag-Quellen mehrere Tracks taggen?
#2
Hi Dano! Hi MP3Tag users!
Now i am new here.
I use MP3Tag since last week. Its a very nice program, and easy to use!!!
While tagged a few mp3 files, i missed a function to automate clicks, because its very usefull if somebody have a large number of mp3-files as me.
So i have written a little script with Autoit, to make the most clicks automatic. For better understand watch the video!
here is a little videosample to view (sorry for bad quality, but it is sufficient to see how the script works)
DESCRIPTION****************
I have tested my automation script only with the dialog "Discogs Web Service Direct Search by Artist and Title". But i think that you can use it with your standard dialog too.
For the people who are interested in the changed dialog, i attached it. Download it and copy the attached src in your sources folder, for Windows Vista it found here C:\Users\USERNAME\AppData\Roaming\Mp3tag\data\sources\
I have edited the source to get a smaller result list (filter the genre "Electronic" and only results after the year 1987, beacause thats i mostly search - you can change it as you want!!
The results will be displayed in order of the year (from old to new)
[IndexUrl]=http://www.discogs.com/advanced_search?artist=%s&genre=Electronic&range=after&year1=1987&btn=Search+Releases&sort=year,asc
HOW TO USE****************
  • now start the actual version 2.49 in german or in english language,
  • be shure that the right Discogs Search Source used one time before, so that MP3tag use it standardly when click the Quick-Search Symbol.
-now click on the MP3TagScript.exe
[b]You can STOP the script with "Esc"
thats all, and have fun with it.
DOWNLOAD*******************
I dont know, why i cant attach rar-files in this forum! But here it is on another way :wink:
Download Script zur Halbautomatisierung von MP3Tag v2.49 in Deutsch &English
EDIT***********************
EDIT: 03.10.2008:17:18 - New Version Uploaded
corrected the number of downscrolling lines after tag 27 Files!
EDIT: 04.11.2008:20:49 - New Version Uploaded for using with version 2.42
EDIT: 02.10.2010:14:45 - New Version Uploaded - much faster now (show the videosample above!) for using with version 2.46c
EDIT: 04.10.2010:20:15 - New Version Uploaded - much faster now (show the videosample above!) and it works now with english language too for using with version 2.46c
EDIT: 29.06.2011:22:05 - New Version Uploaded for using with version 2.49
[b]EDIT: 30.06.2011 - Changed the description
PS: Sorry for my english, but i am german
discogs_Search_by_Artist____Title.src (10.7 KB)
#3
I will update ever the version in the second post of this thread!
#4
This "batch tagging" with autoit and the scripts various people write is very usefull. Unfortunately i am not a programmer so i don't know what can or cannot be done.
Is there a way to make a script or autoit program that could do the following:
Per folder, or from a selection of songs (whatever is easyer, you can decide on the conditions)
lookup the lyrics (for example the leoslyrics script) and import them per song. i don't know if it is possible that it catches only those where it is sure of the lyrics, and skip/disregard those where it doesn't find lyrics or where the window with the list of possibility's you manually choose from pops up.
#5
Im having problems building this with autoit, I keep getting an error on line 27 "Error: Variable used without being declared".
#6
I've added another button and also a download for the compiled file.
#7
Wow dano you really got some skills. Thanks again
#8
updated again - now much faster script! show at the second post of this thread!
#9
and updated again - now the script works with english language too! show at the second post of this thread!
#10
and updated again - show at the second post of this thread!
#11
Does your script what dano's script did or have you modified it?
I don't understand what you are talking about the modified src file in your post (post 2)? There is no src in your rar and your exe works with every src, right?
#12
Sorry - i attached it seperatly again :wink: The difference to the original one is that the search result sort by year of publishing.
But you can also try to run with your script :wink:
#13
So. I have re-edited my post for better overview - i hope so :wink:
