label & catalog number tags
hello guys,
while using mp3tag&rename, i was able to edit such tags as label & catalog number. can't find them in mp3tag. pressed Alt+T & tried to add new tag, but didn't find them in the Field drop-down menu. does mp3tag&rename creates these fields itself & they do not exist elsewhere that in mp3tag&rename? can this tags be edited with Mp3tag?
if these tags exist not only in mp3tag&rename, but in files themselves, then how can appropriate columns be added? what are the value & field? tried %label% - no success.
thanks in advance.
EDIT: grammar.
Just tag a file with Tag & Rename and look for the special tags via [Alt+T]. Make sure, that you're reading the same tag format with Mp3tag that Tag & Rename was writing.
~ Florian
2Florian:
thanks for quick response.
that's exactly, what i did. the problem is that i am unable to find neither label, nor catalog number tags in the Field drop-down menu of the Edit tag info window.
can you please explain, how? :rolleyes:
i don't need to edit tags written in mp3tag&rename, i just need the ability to do it via mp3tag.
If Tag&Rename is writing ID3v2 tags, make sure you activate reading of ID3v2 tags in MP3Tag. Simply press [CTRL+O] in MP3Tag and switch to Tags -> Mpeg on the left tree-view. Check the box "ID3v2" for reading.
After that, select a file you tagged with Tag&Rename and press [ALT+T]. The new dialog will show you all ID3v2 fields read by MP3Tag.
2Sebastian Mares:
ID3v2 was set to read as well as to write & remove.
looked through all the fields available & still didn't find them.
anyway, i think i've resolved my issue.
i have installed mp3tag&rename & added label & catalog number to files i am using for testing. then i went to Mp3tag, selected that files, pressed Alt+T & found out the following:
label = publisher. i am stupid :slight_smile:
catalog number = comment. that's how mp3tag&rename works. it just adds "Catalog Number: <what i put in mp3tag&rename>" in the comment field. therefore, catalog number tag doesn't exist at all.
thank you all for you help!
EDIT: grammar.
Funny - I've just installed Tag&Rename to check how these fields are stored and came to the same conclusions :slight_smile:
Best regards,
~ Florian
15 years after your discussion, I am with the same issue. I think I have the solution: create a field with this value: CATALOG NUMBER.
I have activated it, load a file edited with Traktor and mp3tag recognize the field catalog number prewritten in Traktor.
