I've tested 100 tracks and manually entered label into mp3tag after looking up online.
When I've then re-imported into Rekordbox year is now showing but when added label field it isn't showing what I've manually updated data to. Where am I going wrong?
Is "Label" a supported field in Rekordbox?
Do you have a file that shows the label in Rekordbox?
If so, could open that file in MP3tag and check in the extended tags dialogue Alt-T the field name that shows the label?
Yes I did read the FAQ before posting and seen that it mentioned PUBLISHER.
I have a track in RB that is showing a value in the label field (different to what I've entered) which also shows in Publisher column when clicking alt & T on file in mp3tag.
How do I add PUBLISHER to MP3tag columns as not showing in available list? I added all available fields and the value showing in RB isn't displayed in any of these?
