My program is in portuguese.
How can I change to english ?
The installation process told me about changing language d u r i n g installation, but not the program itself !!!
Thanks
Thanks
There is now way to change the language after you've installed Mp3tag. To change the language, please follow these two steps.
Best regards,
~ Florian
Additionally you may need to remove following file to get column titles into a new language choosen:
C:\Documents and Settings<username>\Application Data\Mp3tag\data\columns.ini
After removal this file will be recreated with strings of an appropriate language.
Please note that removing this file also removes any user-defined columns you've added before from the file list.
Best regards,
~ Florian
