If you could take that suggestion up a for a future version, would be much appreciated.
I now need to to paste lyrics for each track into the lyrics box >> save and close the lyrics box >> close the extended tag box >> move to the next track, repeat the entire procedure 40 to 60 times for all tracks of the opera....
If it's only for pasting the lyrics, you could also add this as a field to the Tag Panel via Preferences β Tag Panel and UNSYNCEDLYRICS (it will be single-line, though) and use β₯β β to save and navigate to the next file without loosing focus.
