I have lot´s of albums and some of them have the leading zero in track count (like 01,02) and some not. Now I have using the "Autonumbering" wizard but I would need something else so I could make sure that all tracks are counted with two numbers.
When you select files and click on "autonumbering" wizard, you'll see a tick box next to "use two digit track numbers". If you want two digit track numbers, tick this box.
I know this option but it is not helping me in this case. I will attach a picture that helps to understand my question. I have many files from different folders open and I do not want to renumber them: just add the missing zero IF it is not present.
Taken from the ever-useful Help docs under 'Pad decimal number with leading zeros'. I always check there first or on the forums via a 'site:mp3tag.de' Google search.
