Unfortunately, when you enable the numbering options with a leading zero (01, 02, ... ,05, ...,10), the program switches to the version with single numbering (1, 2, ... ,5, ...10) and you cannot force it to start them with a leading zero.
The same applies to inserting numbering manually - I insert with a leading zero, and the tag cell immediately "corrects" it and changes it to single numbering.
It is also annoying that you cannot find older versions on the download page (because I wanted to go back to the older version because of the bug described above), there are only about 2 very old ones - 305, 239 and 202.
