When tagging I use the leading zero option. Save repeatedly and all is okay. I can go back to the files after a week or two and view tagging sometimes the leading zero's are randomly missing. Why is this/ what can I do to stop this?
LyricsLover, thank you for your support!
I save repeatedly and the problem still comes back albeit less frequently.
For reference I have 110,621 files (10,173 Folders) in my music collection which includes artwork. It has taken me sometime to work through correcting the leading zeros to only find out the problem is back.
I have two identical hard drives and one NAS (all Seagate), the problem repeats itself.
Very few of the files are mp3. Preference is wav although there many flac files *previous preference).
I'm not aware/sure of any other metadata tools accessing. Other than opening as a Folder via Windows the files are run/accessed c/o JRiver (for me the best sounding/quality media player), no other playback device.
Playing the songs on the music player is not resulting in the missing leading zeros.
The last tagging has retained the leading zero and no newer date.
... and one more:
You could apply Convert>Tag-Tag for TRACK to these files using
Format string: $num(%track%,2)
This should add leading zeros to 1-digit-numbers.
After that press 2x F3 to apply the filter again. And ideally, no file should appear in the file list any more.
If you still find some, check the file format whether that supports leading zeros at all.
